Ana içeriğe geç
Kenwood DRV-N520 Dashcam Motherboard Replacement
Neye ihtiyacın var
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: adım 3, 2 resimden 1. Kenwood DRV-N520 Dashcam Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: adım 4, 3 resimden 1. Kenwood DRV-N520 Dashcam Motherboard Replacement: adım 4, 3 resimden 2. Kenwood DRV-N520 Dashcam Motherboard Replacement: adım 4, 3 resimden 3.
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
Sonuç
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
Bir Yorum
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 196
