Ana içeriğe geç
Kenwood KD-37R Belt Replacement and Modification
Neye ihtiyacın var
  1. Kenwood KD-37R Belt Replacement and Modification, Belt: adım 1, 1 resimden 1.
    • Always dust your turntable before performing any maintenance or repairs.
  2. Kenwood KD-37R Belt Replacement and Modification: adım 2, 1 resimden 1.
    • Remove the rubber mat from the platter and set it aside in a clean, dust free area.
  3. Kenwood KD-37R Belt Replacement and Modification: adım 3, 1 resimden 1.
    • Remove the metal platter by placing your thumb on the center spindle and two to three fingers in one of the holes.
    • Pull the platter up firmly, but carefully.
  4. Kenwood KD-37R Belt Replacement and Modification: adım 4, 1 resimden 1.
    • Remove the old belt.
    • Throw the old belt away if it's damaged.
  5. Kenwood KD-37R Belt Replacement and Modification: adım 5, 1 resimden 1.
    • Turn the metal platter over.
    • Place the new belt around the inner lip of the metal platter, ensuring there are no twists.
  6. Kenwood KD-37R Belt Replacement and Modification: adım 6, 2 resimden 1. Kenwood KD-37R Belt Replacement and Modification: adım 6, 2 resimden 2.
    • Put the metal platter back on the turn table.
    • Use your thumb and forefinger to pull a small section of the belt behind the pulley shaft.
  7. Kenwood KD-37R Belt Replacement and Modification: adım 7, 1 resimden 1.
    • Replace the rubber mat.
    • Play a record to test the new belt.
    • This is when I discovered the belt that was sent to me was slightly too big. Not to fear! We can fix that.
  8. Kenwood KD-37R Belt Replacement and Modification: adım 8, 3 resimden 1. Kenwood KD-37R Belt Replacement and Modification: adım 8, 3 resimden 2. Kenwood KD-37R Belt Replacement and Modification: adım 8, 3 resimden 3.
    • Remove the rubber mat.
    • Before removing the metal platter, carefully remove the belt from behind the pulley shaft.
    • Remove the metal platter and the belt.
  9. Kenwood KD-37R Belt Replacement and Modification: adım 9, 2 resimden 1. Kenwood KD-37R Belt Replacement and Modification: adım 9, 2 resimden 2.
    • Bring two cups of water to a full boil.
  10. Kenwood KD-37R Belt Replacement and Modification: adım 10, 3 resimden 1. Kenwood KD-37R Belt Replacement and Modification: adım 10, 3 resimden 2. Kenwood KD-37R Belt Replacement and Modification: adım 10, 3 resimden 3.
    • Turn off heat.
    • Using tongs, fully submerge the belt into the water.
    • Be careful, the water should be very hot for this to work, and can burn your skin.
    • Let the belt sit in the water for between 6-8 minutes.
  11. Kenwood KD-37R Belt Replacement and Modification: adım 11, 2 resimden 1. Kenwood KD-37R Belt Replacement and Modification: adım 11, 2 resimden 2.
    • Using tongs, remove the belt from the water and let it dry completely.
    • The water may still be very hot.
  12. Kenwood KD-37R Belt Replacement and Modification: adım 12, 1 resimden 1.
    • Repeat steps 5, 6, and 7, and enjoy the music!
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Tim
229 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 676
