Ana içeriğe geç
Kenwood KDC-BT362U Button Replacement
Neye ihtiyacın var
  1. Kenwood KDC-BT362U Button  Replacement, Front Panel: adım 1, 1 resimden 1.
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U Button  Replacement: adım 2, 2 resimden 1. Kenwood KDC-BT362U Button  Replacement: adım 2, 2 resimden 2.
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U Button  Replacement: adım 3, 2 resimden 1. Kenwood KDC-BT362U Button  Replacement: adım 3, 2 resimden 2.
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U Button  Replacement: adım 4, 2 resimden 1. Kenwood KDC-BT362U Button  Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U Button  Replacement: adım 5, 1 resimden 1.
    • Remove the front panel.
  6. Kenwood KDC-BT362U Button  Replacement, Button: adım 6, 1 resimden 1.
    • Use the Phillips #0 Screwdriver to remove the four screws.
  7. Kenwood KDC-BT362U Button  Replacement: adım 7, 2 resimden 1. Kenwood KDC-BT362U Button  Replacement: adım 7, 2 resimden 2.
    • Use the plastic opening tool to pry it open.
  8. Kenwood KDC-BT362U Button  Replacement: adım 8, 2 resimden 1. Kenwood KDC-BT362U Button  Replacement: adım 8, 2 resimden 2.
    • Lift and remove the motherboard to reveal the inside of the front panel.
  9. Kenwood KDC-BT362U Button  Replacement: adım 9, 2 resimden 1. Kenwood KDC-BT362U Button  Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to lift up and remove the cover.
  10. Kenwood KDC-BT362U Button  Replacement: adım 10, 1 resimden 1.
    • The buttons are now able to be removed and replaced if damaged or missing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Steven Chov
349 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Cagle Fall 2016 USF Tampa, Team 2-5, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 758
