Ana içeriğe geç
  1. Locate the face-plate eject button.
    • Locate the face-plate eject button.
  2. Press the eject button with your forefinger. Remove the face-plate.
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Starting on the top side, pop the front panel frame out. Remove the face-plate frame.
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Use the plastic opening tool to pry open the tabs. Repeat on the opposite side.
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Remove the front panel.
    • Remove the front panel.
  6. Use the Phillips #0 Screwdriver to remove the four screws.
    • Use the Phillips #0 Screwdriver to remove the four screws.
  7. Use the plastic opening tool to pry it open. Use the plastic opening tool to pry it open.
    • Use the plastic opening tool to pry it open.
  8. Lift and remove the motherboard to reveal the inside of the front panel. Lift and remove the motherboard to reveal the inside of the front panel.
    • Lift and remove the motherboard to reveal the inside of the front panel.
  9. Use the metal spudger to straighten out the six pegs to allow the removal of the LCD Screen. Use the metal spudger to straighten out the six pegs to allow the removal of the LCD Screen.
    • Use the metal spudger to straighten out the six pegs to allow the removal of the LCD Screen.
  10. Lift the LCD Screen to remove and replace it. Lift the LCD Screen to remove and replace it.
    • Lift the LCD Screen to remove and replace it.
Sonuç
Steven Chov
301 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 2-5, Cagle Fall 2016 USF Tampa, Team 2-5, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 4
Her zaman: 420
