Ana içeriğe geç
Kenwood KDC-BT565U Fuse Replacement
Neye ihtiyacın var
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: adım 1, 1 resimden 1.
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: adım 2, 2 resimden 1. Kenwood KDC-BT565U Fuse Replacement: adım 2, 2 resimden 2.
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
Sonuç
To reassemble, follow these instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Darren Evans
273 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Lacy Spring 2017 USF Tampa, Team S2-G5, Lacy Spring 2017 üyesi
USFT-LACY-S17S2G5
4 Üyeler
11 adet Kılavuz yazıldı
7 Yorum
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - Yanıt
it does not explain how to pull the reciever out.
d_lalande - Yanıt
same problem, how to remove the receiver
Jason Armondo - Yanıt
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - Yanıt
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 53
Son 30 gün: 169
Her zaman: 21,318
