Ana içeriğe geç
Keurig B60 Puncture Needle Replacement
Neye ihtiyacın var
  1. Keurig B60 Puncture Needle Replacement, Handle: adım 1, 1 resimden 1.
    • Lift the handle
  2. Keurig B60 Puncture Needle Replacement: adım 2, 3 resimden 1. Keurig B60 Puncture Needle Replacement: adım 2, 3 resimden 2. Keurig B60 Puncture Needle Replacement: adım 2, 3 resimden 3.
    • Locate and remove the two 9.5 mm Torx T15 screws on both sides of the handle.
  3. Keurig B60 Puncture Needle Replacement: adım 3, 2 resimden 1. Keurig B60 Puncture Needle Replacement: adım 3, 2 resimden 2.
    • Remove the broken handle and replace with the new one
  4. Keurig B60 Puncture Needle Replacement, Puncture Needle: adım 4, 1 resimden 1.
    • Locate and remove the two 9.5 mm Phillips #1 screws.
    • Remove the plastic ring around the K-Cup Pack Holder
  5. Keurig B60 Puncture Needle Replacement: adım 5, 1 resimden 1.
    • Remove the two 9.5 mm Phillips #1 screws on the underside of the lid.
  6. Keurig B60 Puncture Needle Replacement: adım 6, 2 resimden 1. Keurig B60 Puncture Needle Replacement: adım 6, 2 resimden 2.
    • Detach the lid from the Keurig.
  7. Keurig B60 Puncture Needle Replacement: adım 7, 1 resimden 1.
    • Locate and remove the two 9.5 mm Phillips #1 screws on the top of the puncture needle.
  8. Keurig B60 Puncture Needle Replacement: adım 8, 3 resimden 1. Keurig B60 Puncture Needle Replacement: adım 8, 3 resimden 2. Keurig B60 Puncture Needle Replacement: adım 8, 3 resimden 3.
    • Squeeze and pull on the hose to remove it from the Puncture Needle
    • Puncture needle should now be exposed
  9. Keurig B60 Puncture Needle Replacement: adım 9, 3 resimden 1. Keurig B60 Puncture Needle Replacement: adım 9, 3 resimden 2. Keurig B60 Puncture Needle Replacement: adım 9, 3 resimden 3.
    • Remove the Puncture Needle Assembly from Keurig
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jake Wynn
830 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-7, Maness Spring 2016 Cal Poly, Team 1-7, Maness Spring 2016 üyesi
CPSU-MANESS-S16S1G7
5 Üyeler
2 Yorum
Keurig B60 Puncture Needle Replacement. I need the punture needlees,upper and lower for this model.
johnneypa - Yanıt
I will be completing this guide but where do you get the replacement puncture needles for this model??
John Lawson
John Lawson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 166
Her zaman: 30,127
