Ana içeriğe geç
Keurig B70 Platinum Base Replacement
Neye ihtiyacın var
  1. Keurig B70 Platinum Base Replacement, Base: adım 1, 2 resimden 1. Keurig B70 Platinum Base Replacement, Base: adım 1, 2 resimden 2.
    • Turn off and unplug the Keurig before starting.
    • Turn the Keurig upside down so the metal base is exposed.
    • Remove the five 12.0 mm screws.
    FixBot'a Sor
    Yorum Ekle
  2. Keurig B70 Platinum Base Replacement: adım 2, 2 resimden 1. Keurig B70 Platinum Base Replacement: adım 2, 2 resimden 2.
    • Lift the metal plate off the Keurig and hang it over the side of the device.
    • Be careful! The metal plate is sharp!
    • There are wires connected to the metal plate. Make sure the wires are not in the way of the internal components.
    FixBot'a Sor
    Yorum Ekle
  3. Keurig B70 Platinum Base Replacement: adım 3, 3 resimden 1. Keurig B70 Platinum Base Replacement: adım 3, 3 resimden 2. Keurig B70 Platinum Base Replacement: adım 3, 3 resimden 3.
    • Remove the three 11.0 mm screws located on the upper left side of the base from within the tub-looking area.
    • Pull out the red and white wires and put it off to the side of the Keurig.
    FixBot'a Sor
    Yorum Ekle
  4. Keurig B70 Platinum Base Replacement: adım 4, 3 resimden 1. Keurig B70 Platinum Base Replacement: adım 4, 3 resimden 2. Keurig B70 Platinum Base Replacement: adım 4, 3 resimden 3.
    • Pull out the water collector by gripping it tightly and lifting upwards.
    FixBot'a Sor
    Yorum Ekle
  5. Keurig B70 Platinum Base Replacement: adım 5, 3 resimden 1. Keurig B70 Platinum Base Replacement: adım 5, 3 resimden 2. Keurig B70 Platinum Base Replacement: adım 5, 3 resimden 3.
    • Lift the tube, connected to the tank, off the black plastic hook and leave it off to the side of the hook.
    FixBot'a Sor
    Yorum Ekle
  6. Keurig B70 Platinum Base Replacement: adım 6, 3 resimden 1. Keurig B70 Platinum Base Replacement: adım 6, 3 resimden 2. Keurig B70 Platinum Base Replacement: adım 6, 3 resimden 3.
    • Pull the power cord out from the plastic holder located near the water tank.
    • This step requires a bit of force so don't be afraid to pull harder!
    FixBot'a Sor
    Yorum Ekle
  7. Keurig B70 Platinum Base Replacement: adım 7, 2 resimden 1. Keurig B70 Platinum Base Replacement: adım 7, 2 resimden 2.
    • Remove the six 13.0 mm screws.
    FixBot'a Sor
    Yorum Ekle
  8. Keurig B70 Platinum Base Replacement: adım 8, 3 resimden 1. Keurig B70 Platinum Base Replacement: adım 8, 3 resimden 2. Keurig B70 Platinum Base Replacement: adım 8, 3 resimden 3.
    • Lift the metal base and hover it over the opening of the black plastic base.
    • Carefully raise the plastic base over the metal base until it is removed.
    • Make sure to pull the power cord through the base as well!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Steven Tran
350 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G6
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 993
