Ana içeriğe geç
Keurig B70 Platinum Brewer Handle Replacement
Neye ihtiyacın var
  1. Keurig B70 Platinum Brewer Handle Replacement, Brewer Handle: adım 1, 3 resimden 1. Keurig B70 Platinum Brewer Handle Replacement, Brewer Handle: adım 1, 3 resimden 2. Keurig B70 Platinum Brewer Handle Replacement, Brewer Handle: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Turn off and unplug the Keurig before starting.
    • Lay the Keurig on its back and open the lid.
    • Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
    • Be careful when removing the screws. There is a sharp puncture needle!
    • You may need to use tweezers to get the screws out.
  2. Keurig B70 Platinum Brewer Handle Replacement: adım 2, 2 resimden 1. Keurig B70 Platinum Brewer Handle Replacement: adım 2, 2 resimden 2.
    • Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
  3. Keurig B70 Platinum Brewer Handle Replacement: adım 3, 2 resimden 1. Keurig B70 Platinum Brewer Handle Replacement: adım 3, 2 resimden 2.
    • Lift and pull the black plastic cover away from the Keurig.
  4. Keurig B70 Platinum Brewer Handle Replacement: adım 4, 1 resimden 1.
    • Push the handle back and upward to detach it from the Keurig.
Sonuç
Thu Hoang
217 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 657
