Ana içeriğe geç
Keurig B70 Platinum Puncture Needle Replacement
Neye ihtiyacın var
  1. Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: adım 1, 3 resimden 1. Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: adım 1, 3 resimden 2. Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Turn off and unplug the Keurig before starting.
    • Lay the Keurig on its back and open the lid.
    • Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
    • Be careful when removing the screws. There is a sharp puncture needle!
    • You may need to use tweezers to get the screws out.
  2. Keurig B70 Platinum Puncture Needle Replacement: adım 2, 2 resimden 1. Keurig B70 Platinum Puncture Needle Replacement: adım 2, 2 resimden 2.
    • Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
  3. Keurig B70 Platinum Puncture Needle Replacement: adım 3, 2 resimden 1. Keurig B70 Platinum Puncture Needle Replacement: adım 3, 2 resimden 2.
    • Lift and pull the black plastic cover away from the Keurig.
  4. Keurig B70 Platinum Puncture Needle Replacement: adım 4, 1 resimden 1.
    • Push the handle back and upward to detach it from the Keurig.
  5. Keurig B70 Platinum Puncture Needle Replacement, Puncture Needle: adım 5, 2 resimden 1. Keurig B70 Platinum Puncture Needle Replacement, Puncture Needle: adım 5, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two 7.0 mm screws located on the sides of the tube near the puncture needle.
  6. Keurig B70 Platinum Puncture Needle Replacement: adım 6, 2 resimden 1. Keurig B70 Platinum Puncture Needle Replacement: adım 6, 2 resimden 2.
    • Using both hands, pull the puncture needle tube and the Keurig tube apart to disconnect the tubes.
    • Don't be afraid to pull hard! The tubes are tightly connected.
  7. Keurig B70 Platinum Puncture Needle Replacement: adım 7, 2 resimden 1. Keurig B70 Platinum Puncture Needle Replacement: adım 7, 2 resimden 2.
    • Slide the black plastic ring, which holds the puncture needle tube down, off of the tube.
  8. Keurig B70 Platinum Puncture Needle Replacement: adım 8, 3 resimden 1. Keurig B70 Platinum Puncture Needle Replacement: adım 8, 3 resimden 2. Keurig B70 Platinum Puncture Needle Replacement: adım 8, 3 resimden 3.
    • Using a Phillips #2 screwdriver, remove the two 9.0 mm screws next to the detached tube.
    • Hold on to the puncture needle when removing the screws to ensure that the puncture needle does not fall and cause injury.
  9. Keurig B70 Platinum Puncture Needle Replacement: adım 9, 3 resimden 1. Keurig B70 Platinum Puncture Needle Replacement: adım 9, 3 resimden 2. Keurig B70 Platinum Puncture Needle Replacement: adım 9, 3 resimden 3.
    • Gently pull the puncture needle down and out from the Keurig.
Sonuç
Steven Tran
329 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 56
Her zaman: 1,515
