Ana içeriğe geç
Keurig B70 Platinum Water Filter Replacement
Neye ihtiyacın var
  1. Keurig B70 Platinum Water Filter Replacement, Water Filter: adım 1, 3 resimden 1. Keurig B70 Platinum Water Filter Replacement, Water Filter: adım 1, 3 resimden 2. Keurig B70 Platinum Water Filter Replacement, Water Filter: adım 1, 3 resimden 3.
    • Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
    • Be sure to empty the reservoir before continuing to the next step.
    FixBot'a Sor
    Yorum Ekle
  2. Keurig B70 Platinum Water Filter Replacement: adım 2, 3 resimden 1. Keurig B70 Platinum Water Filter Replacement: adım 2, 3 resimden 2. Keurig B70 Platinum Water Filter Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the three 11.0 mm screws from the reservoir filter.
    • You may need to use tweezers to pull out the screws.
    FixBot'a Sor
    Yorum Ekle
  3. Keurig B70 Platinum Water Filter Replacement: adım 3, 3 resimden 1. Keurig B70 Platinum Water Filter Replacement: adım 3, 3 resimden 2. Keurig B70 Platinum Water Filter Replacement: adım 3, 3 resimden 3.
    • Firmly twist the filter counterclockwise to remove it.
    • When adding the replacement filter, make sure the filter lines up with the screw holes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Emily Ramirez
103 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G6
4 Üyeler
10 adet Kılavuz yazıldı
4Kılavuz Yorumları
What are the two items inside the water resin?
There is the round item, and next to it an oblong item. I am really confused
Joan - Yanıt Paylaş
The round item with 3 screws is the built in filter. The oblong item is the water level gauge.
Dacaria L - Yanıt Paylaş
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
Joan - Yanıt Paylaş
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 100
Her zaman: 13,259
