Ana içeriğe geç
Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement
Neye ihtiyacın var
  1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cold Water Reserve Lid: adım 1, 2 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cold Water Reserve Lid: adım 1, 2 resimden 2.
    • Lift the cold water reserve lid up to reveal its hinge.
    • Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
  2. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 2, 1 resimden 1.
    • Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
  3. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cup Holder: adım 3, 3 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cup Holder: adım 3, 3 resimden 2. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cup Holder: adım 3, 3 resimden 3.
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  4. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 4, 2 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 4, 2 resimden 2.
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
  5. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Top Needle: adım 5, 2 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Top Needle: adım 5, 2 resimden 2.
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  6. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 6, 3 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 6, 3 resimden 2. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 6, 3 resimden 3.
    • Once you remove the screws, the top cover should come out.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  7. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 7, 1 resimden 1.
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  8. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cold Water Reserve Arm: adım 8, 3 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cold Water Reserve Arm: adım 8, 3 resimden 2. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement, Cold Water Reserve Arm: adım 8, 3 resimden 3.
    • Remove two 14 mm Phillips #2 screws.
    • Remove two 12 mm Phillips #2 screws.
    • Lift the arm off the assembly. This will reveal the tank hole as shown.
    • It is recommended that you clog the tank hole with a napkin or something similar in order to prevent small parts from falling into the heating element.
  9. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 9, 2 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 9, 2 resimden 2.
    • Remove two 9.7 mm Phillips #2 screws.
    • Remove two 11.5 mm Phillips #2 screws.
    • Remove the cold water reserve arm's plug from the arm itself in order to allow access to the base screws.
  10. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 10, 2 resimden 1. Keurig K10 MINI PLUS Cold Water Reserve Arm Replacement: adım 10, 2 resimden 2.
    • Remove two 18 mm Phillips #2 screws.
    • Finally, detach the arm from the cold water reserve basin.
Sonuç
Timmur
169 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 789
