Ana içeriğe geç
Keurig K10 MINI PLUS Top Needle Replacement
Neye ihtiyacın var
  1. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: adım 1, 3 resimden 1. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: adım 1, 3 resimden 2. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: adım 1, 3 resimden 3.
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 MINI PLUS Top Needle Replacement: adım 2, 2 resimden 1. Keurig K10 MINI PLUS Top Needle Replacement: adım 2, 2 resimden 2.
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
  3. Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: adım 3, 2 resimden 1. Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: adım 3, 2 resimden 2.
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Top Needle Replacement: adım 4, 3 resimden 1. Keurig K10 MINI PLUS Top Needle Replacement: adım 4, 3 resimden 2. Keurig K10 MINI PLUS Top Needle Replacement: adım 4, 3 resimden 3.
    • Once you remove the screws, the top cover should come out.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Top Needle Replacement: adım 5, 1 resimden 1.
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mark Henein
369 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Blackwell Winter 2016 USF Tampa, Team 17-6, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G6
2 Üyeler
Bir Yorum
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
tbushwacker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 4,818
