Ana içeriğe geç
Keurig K10 MINI PLUS Water Pump Replacement
Neye ihtiyacın var
  1. Keurig K10 MINI PLUS Water Pump Replacement, Cold Water Reserve Lid: adım 1, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement, Cold Water Reserve Lid: adım 1, 2 resimden 2.
    • Lift the cold water reserve lid up to reveal its hinge.
    • Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
  2. Keurig K10 MINI PLUS Water Pump Replacement: adım 2, 1 resimden 1.
    • Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
  3. Keurig K10 MINI PLUS Water Pump Replacement, Top Needle: adım 3, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement, Top Needle: adım 3, 2 resimden 2.
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Water Pump Replacement: adım 4, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 4, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement: adım 4, 3 resimden 3.
    • Once you remove the screws, the top cover should come out.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Water Pump Replacement: adım 5, 1 resimden 1.
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  6. Keurig K10 MINI PLUS Water Pump Replacement, Cold Water Reserve Arm: adım 6, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement, Cold Water Reserve Arm: adım 6, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement, Cold Water Reserve Arm: adım 6, 3 resimden 3.
    • Remove two 14 mm Phillips #2 screws.
    • Remove two 12 mm Phillips #2 screws.
    • Lift the arm off the assembly. This will reveal the tank hole as shown.
    • It is recommended that you clog the tank hole with a napkin or something similar in order to prevent small parts from falling into the heating element.
  7. Keurig K10 MINI PLUS Water Pump Replacement: adım 7, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 7, 2 resimden 2.
    • Remove two 9.7 mm Phillips #2 screws.
    • Remove two 11.5 mm Phillips #2 screws.
    • Remove the cold water reserve arm's plug from the arm itself in order to allow access to the base screws.
  8. Keurig K10 MINI PLUS Water Pump Replacement: adım 8, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 8, 2 resimden 2.
    • Remove two 18 mm Phillips #2 screws.
    • Finally, detach the arm from the cold water reserve basin.
  9. Keurig K10 MINI PLUS Water Pump Replacement, Dispenser Head: adım 9, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement, Dispenser Head: adım 9, 2 resimden 2.
    • Pull the head assembly forward to reveal the two plastic axle points that keep the head assembly attached to the base.
    • There is a spring concealed by a white piece as shown.
  10. Keurig K10 MINI PLUS Water Pump Replacement: adım 10, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 10, 2 resimden 2.
    • Using the iFixit Opening Tool, gently pry apart the plastic head assembly piece from both the body's axles and its left to remove it.
  11. Keurig K10 MINI PLUS Water Pump Replacement, Brew Button: adım 11, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement, Brew Button: adım 11, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement, Brew Button: adım 11, 3 resimden 3.
    • Screws circled in red may be hard to reach and will require a screw driver with a neck width of 5mm or less.
  12. Keurig K10 MINI PLUS Water Pump Replacement: adım 12, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 12, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement: adım 12, 3 resimden 3.
    • Detach the seat by giving it a firm tug up.
  13. Keurig K10 MINI PLUS Water Pump Replacement: adım 13, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 13, 2 resimden 2.
    • Flip over the device.
    • Remove four 11.5 mm Phillips #2 screws.
  14. Keurig K10 MINI PLUS Water Pump Replacement: adım 14, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 14, 2 resimden 2.
    • Reposition the metal lid while keeping the heat sink attached in order to reach the screws underneath.
    • It is recommended that you leave the heat sink aside as it contains thermal paste.
  15. Keurig K10 MINI PLUS Water Pump Replacement: adım 15, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 15, 2 resimden 2.
    • Be careful not to confuse these two screws for the ones behind them.
  16. Keurig K10 MINI PLUS Water Pump Replacement: adım 16, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 16, 2 resimden 2.
    • Turn the device right side up again.
  17. Keurig K10 MINI PLUS Water Pump Replacement: adım 17, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 17, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement: adım 17, 3 resimden 3.
    • Begin to pry open the front plate using the iFixit Opening Tool as shown.
    • Pry upwards in order to take the cover off.
  18. Keurig K10 MINI PLUS Water Pump Replacement: adım 18, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 18, 2 resimden 2.
    • Remove the front plate.
    • Be careful of the wires here.
  19. Keurig K10 MINI PLUS Water Pump Replacement: adım 19, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 19, 2 resimden 2.
    • Remove one 9.7 mm Phillips #2 screws.
  20. Keurig K10 MINI PLUS Water Pump Replacement: adım 20, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 20, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement: adım 20, 3 resimden 3.
    • Remove the button housing to access the buttons.
    • The brew buttons can be easily popped out of place by pushing inwards from the front of the unit.
  21. Keurig K10 MINI PLUS Water Pump Replacement, Water Pump: adım 21, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement, Water Pump: adım 21, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement, Water Pump: adım 21, 3 resimden 3.
  22. Keurig K10 MINI PLUS Water Pump Replacement: adım 22, 3 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 22, 3 resimden 2. Keurig K10 MINI PLUS Water Pump Replacement: adım 22, 3 resimden 3.
    • Pry open the left, right, and back of the back plate by pulling out and up.
    • Do not be afraid to be fairly forceful when removing the back plate—it is snapped together fairly tight.
  23. Keurig K10 MINI PLUS Water Pump Replacement: adım 23, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 23, 2 resimden 2.
    • Rotate the device to reveal the pump side.
    • Remove one 9.7 mm Phillips #2 screw.
  24. Keurig K10 MINI PLUS Water Pump Replacement: adım 24, 2 resimden 1. Keurig K10 MINI PLUS Water Pump Replacement: adım 24, 2 resimden 2.
    • Remove the power connectors attached to the water pump.
    • Remove the water hose attached to the water pump.
    • Remove the water pump itself.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Matt Bav
577 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G7
3 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
Great directions on how to disassemble and get at the water pump. I just can’t find where or how to order a replacement pump. Can you help?
jameslitrun - Yanıt
I was very surprised I needed a guide to take this silly little coffee maker apart, but boy did I.
I've rebuilt entire engines that were less of a headache.
Thanks for the great write up (especially the heatsink pointer, never can find the last tube of thermal paste I bought)
Layf Ditch - Yanıt
this is great, it helps save my Keurig K10. I was able to open it up, and clean the pump motor due to corrossion, and it works fine now.
hunter - Yanıt
Thank you a lot!!! you save me too much time
gabriel patricio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 5,781
