Ana içeriğe geç
Keurig K10 Mini Plus Cup Holder Replacement
Neye ihtiyacın var
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: adım 1, 3 resimden 1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: adım 1, 3 resimden 2. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: adım 1, 3 resimden 3.
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: adım 2, 2 resimden 1. Keurig K10 Mini Plus Cup Holder Replacement: adım 2, 2 resimden 2.
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Sonuç
Mark Henein
369 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Blackwell Winter 2016 USF Tampa, Team 17-6, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G6
2 Üyeler
Bir Yorum
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,402
