Ana içeriğe geç
Keurig K40 Bottom Water Filter Replacement
Neye ihtiyacın var
  1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: adım 1, 2 resimden 1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: adım 1, 2 resimden 2.
    • Flip the device on its side so that the metal faces you.
    • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
  2. Keurig K40 Bottom Water Filter Replacement: adım 2, 2 resimden 1. Keurig K40 Bottom Water Filter Replacement: adım 2, 2 resimden 2.
    • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
    • The wires do not need to be cut as this repair will not harm or use them.
  3. Keurig K40 Bottom Water Filter Replacement: adım 3, 2 resimden 1. Keurig K40 Bottom Water Filter Replacement: adım 3, 2 resimden 2.
    • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
    • Pull the pump back to remove it from the slot it was in.
  4. Keurig K40 Bottom Water Filter Replacement: adım 4, 1 resimden 1.
    • Grip where the filter and the flow line connect and pull apart until they are separated.
    • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
jonathan
738 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G1
3 Üyeler
5 adet Kılavuz yazıldı
13Kılavuz Yorumları
Where do you obtain a new filter?
Anthony Montoya - Yanıt
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - Yanıt
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - Yanıt
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - Yanıt
The answer seems to be: “You don’t.”
Van Davis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 35
Son 30 gün: 115
Her zaman: 35,847
