Ana içeriğe geç
Keurig K40 Open/Close Sensor Replacement
Neye ihtiyacın var
  1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: adım 1, 1 resimden 1.
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Open/Close Sensor Replacement: adım 2, 1 resimden 1.
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Open/Close Sensor Replacement: adım 3, 2 resimden 1. Keurig K40 Open/Close Sensor Replacement: adım 3, 2 resimden 2.
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Open/Close Sensor Replacement: adım 4, 2 resimden 1. Keurig K40 Open/Close Sensor Replacement: adım 4, 2 resimden 2.
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
  5. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: adım 5, 2 resimden 1. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: adım 5, 2 resimden 2.
    • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
    • Locate where the connections are soldered to the sensor
  6. Keurig K40 Open/Close Sensor Replacement: adım 6, 1 resimden 1.
    • Melt the solder that is connected to the sensor.
    • Be careful to avoid any rubber and try to only contact the metal making the connection.
  7. Keurig K40 Open/Close Sensor Replacement: adım 7, 1 resimden 1.
    • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
    • Be careful not to touch the end of the soldering iron.
Sonuç
Bir başkası bu kılavuzu tamamladı.
jonathan
738 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G1
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 3,765
