Ana içeriğe geç
Keurig K55 Lid Spring Replacement
Neye ihtiyacın var
    1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: adım 1, 3 resimden 1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: adım 1, 3 resimden 2. Keurig K55 Lid Spring Replacement, Secondary Water Pump: adım 1, 3 resimden 3.
      • Lift the silver handle up.
      • Locate the screw and washer holding the handle in place on each side.
      • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Keurig K55 Lid Spring Replacement: adım 2, 2 resimden 1. Keurig K55 Lid Spring Replacement: adım 2, 2 resimden 2.
      • Grab the handle and pull it upward and toward the rear of the device.
      • Lift the lid to the fully open position.
      • Remove the two 11mm Phillips screws located on the upper part of the device.
      • Be careful removing the screws; the needle here may be sharp.
      FixBot'a Sor
      Yorum Ekle
    3. Keurig K55 Lid Spring Replacement: adım 3, 3 resimden 1. Keurig K55 Lid Spring Replacement: adım 3, 3 resimden 2. Keurig K55 Lid Spring Replacement: adım 3, 3 resimden 3.
      • Lower the lid to just before its closing position.
      • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
      • Gently pull the top cover upward and toward the front of the device to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. Keurig K55 Lid Spring Replacement: adım 4, 3 resimden 1. Keurig K55 Lid Spring Replacement: adım 4, 3 resimden 2. Keurig K55 Lid Spring Replacement: adım 4, 3 resimden 3.
      • Remove the two 11mm Phillips head screws securing the water pump.
      • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
      • Pull the other line from the water pump.
      FixBot'a Sor
      Yorum Ekle
    1. Keurig K55 Lid Spring Replacement, Lid Spring: adım 5, 2 resimden 1. Keurig K55 Lid Spring Replacement, Lid Spring: adım 5, 2 resimden 2.
      • Pull the spring off the front hook using two fingers.
      • The spring has a lot of tension, so grip the spring end tightly.
      FixBot'a Sor
      Yorum Ekle
    2. Keurig K55 Lid Spring Replacement: adım 6, 2 resimden 1. Keurig K55 Lid Spring Replacement: adım 6, 2 resimden 2.
      • Pull the spring off the other hook.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
William O'Brien
500 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, Livingston Winter 2018 Cal Poly, Team S1-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S1G3
4 Üyeler
30 adet Kılavuz yazıldı
2Kılavuz Yorumları
What is the small plastic/rubber angled water line part that the front part of the water pump valve is inserted into ?
Joe K - Yanıt Paylaş
Well i might have described it as a water pump in my above message, but from what I've read on here it is a check valve, so what is the rubber/plastic small angled water line part that the front of the check valve is inserted into !
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 51
Her zaman: 2,601
