Ana içeriğe geç
Keurig K55 Water Filter Replacement
Neye ihtiyacın var
  1. Keurig K55 Water Filter Replacement, Charcoal water filter: adım 1, 1 resimden 1.
    • Soak the new charcoal filter in water for 5 minutes.
  2. Keurig K55 Water Filter Replacement: adım 2, 3 resimden 1. Keurig K55 Water Filter Replacement: adım 2, 3 resimden 2. Keurig K55 Water Filter Replacement: adım 2, 3 resimden 3.
    • Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
  3. Keurig K55 Water Filter Replacement: adım 3, 1 resimden 1.
    • Remove the lid from the water reservoir and empty any remaining water from the tank.
  4. Keurig K55 Water Filter Replacement: adım 4, 2 resimden 1. Keurig K55 Water Filter Replacement: adım 4, 2 resimden 2.
    • Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
  5. Keurig K55 Water Filter Replacement: adım 5, 2 resimden 1. Keurig K55 Water Filter Replacement: adım 5, 2 resimden 2.
    • To remove the old filter, pinch both sides of the filter holder at the base and pull it apart. Remove the old filter by lifting it out of the filter holder.
    • Dispose of old water filter cartridge.
  6. Keurig K55 Water Filter Replacement: adım 6, 1 resimden 1.
    • Take the soaked water filter and rinse it under running water for 60 seconds.
  7. Keurig K55 Water Filter Replacement: adım 7, 2 resimden 1. Keurig K55 Water Filter Replacement: adım 7, 2 resimden 2.
    • Place new water filter cartridge into the upper filter holder.
    • Snap the bottom of the filter holder back on by aligning the tabs with the spaces
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 1,126
