Ana içeriğe geç
Keyboard Keys Replacement Guide
Neye ihtiyacın var
  1. Keyboard Keys Replacement Guide, Keyboard Keys: adım 1, 3 resimden 1. Keyboard Keys Replacement Guide, Keyboard Keys: adım 1, 3 resimden 2. Keyboard Keys Replacement Guide, Keyboard Keys: adım 1, 3 resimden 3.
    • Before placing, check that the key is properly orientated. The letter side should be face up.
    • Place the missing key onto the keyboard in the desired orientation. Once aligned, press firmly until the key snaps into place. This will not require large amounts of force. If it does not snap in, realign the key and try again.
    FixBot'a Sor
    Yorum Ekle
  2. Keyboard Keys Replacement Guide: adım 2, 1 resimden 1.
    • Large rectangular keys need to be attached to the small metal bar to be attached properly. There are two ways to do this.
    FixBot'a Sor
    Yorum Ekle
  3. Keyboard Keys Replacement Guide: adım 3, 2 resimden 1. Keyboard Keys Replacement Guide: adım 3, 2 resimden 2.
    • Before installing, the plastic receivers on the on the bottom of key need to be lined up properly with the metal pins.
    • Option one is to line up the receivers with the metal bar from step 2 and apply pressure to attach.
    FixBot'a Sor
    Yorum Ekle
  4. Keyboard Keys Replacement Guide: adım 4, 3 resimden 1. Keyboard Keys Replacement Guide: adım 4, 3 resimden 2. Keyboard Keys Replacement Guide: adım 4, 3 resimden 3.
    • Option two is to be used if the key cannot be attached without removing the metal bar.
    • Pull the metal bar gently from one side to unseat it from the keyboard and allow it to be removed.
    • Attach the metal bar to the receivers on the back of the key.
    • Seat the metal bar into the hole on one side, and then the other. Then press firmly to attach the key.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Steven Park
420 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-5, Catania Spring 2016 UMass Dartmouth, Team 7-5, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G5
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Great guide! One thing worth adding: laptop keys actually come in three retainer clip types — standard scissor (most common, two interlocking plastic arms), butterfly/inverted V (older MacBooks, very fragile), and snap-on single-piece clips (found on some Lenovo ThinkPads). The rubber cup underneath is equally important — if it's flattened or torn, the key will feel mushy even after reinstalling the cap. When diagnosing a wobbly key, check whether the clip is bent or cracked at the hinge point before ordering a replacement, since that's the component that fails most often.
Jeff Horton - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 57
Son 30 gün: 218
Her zaman: 14,831
