Ana içeriğe geç
Keyboard replacement on a why! W253EU
Neye ihtiyacın var
  1. Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 1. Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 2. Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 3.
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Keyboard replacement on a why! W253EU, Keyboard: adım 2, 3 resimden 1. Keyboard replacement on a why! W253EU, Keyboard: adım 2, 3 resimden 2. Keyboard replacement on a why! W253EU, Keyboard: adım 2, 3 resimden 3.
    • Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
    • Insert a standard screwdriver into the slot in the cover above the keyboard.
    • Lift the cover with the usual care.
  3. Keyboard replacement on a why! W253EU: adım 3, 3 resimden 1. Keyboard replacement on a why! W253EU: adım 3, 3 resimden 2. Keyboard replacement on a why! W253EU: adım 3, 3 resimden 3.
    • Use a Phillips # 1 screwdriver to remove the four screws securing the keyboard in the upper part.
  4. Keyboard replacement on a why! W253EU: adım 4, 2 resimden 1. Keyboard replacement on a why! W253EU: adım 4, 2 resimden 2.
    • Turn the keyboard towards the screen.
    • Carefully remove the connection cable in the direction of the plug axis.
Sonuç
For reassembly, follow the instructions in reverse order.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 569
