Ana içeriğe geç
Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly
  1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the USB/Power Off Keyboard: adım 1, 2 resimden 1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the USB/Power Off Keyboard: adım 1, 2 resimden 2.
    • Unplug the keyboard and toggle the leftmost switch to the 'Off" Position
    • For reference, the switches are located on the top of the keyboard.
  2. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: adım 2, 3 resimden 1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: adım 2, 3 resimden 2. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: adım 2, 3 resimden 3.
    • Using a keycap puller, carefully remove the keys from the keyboard
    • NEVER attempt to remove the keyboard keys on any keyboard without a keycap puller or tool specialized to remove keyboard keys, not using the correct tool may damage the keys
  3. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Confirm switches are hot-swappable: adım 3, 2 resimden 1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Confirm switches are hot-swappable: adım 3, 2 resimden 2.
    • Check that your switches are hot-swappable. If they are not, trying to remove them will damage your keyboard.
    • The mechanical switches are NOT hot-swappable, and the colored stem is smaller and more oblong.
    • The optical switches are hot-swappable, and they have a larger colored stem which is mostly square.
  4. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: adım 4, 3 resimden 1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: adım 4, 3 resimden 2. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: adım 4, 3 resimden 3.
    • Use a switch puller to remove the switches.
    • If you have the included switch puller from Keychrone, it may be tough removing said switches.
    • Each switch has small tabs on the corners to grab and remove them. (The Included switch puller might require extra strength to remove)
  5. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the Chassis Screws: adım 5, 1 resimden 1.
    • Use a # 1 philips drill bit to remove the 4 screws on the keyboard
  6. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: adım 6, 3 resimden 1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: adım 6, 3 resimden 2. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: adım 6, 3 resimden 3.
    • Use a spudger or another wedge tool to pry open the plastic base from the aluminum chassis.
    • Use caution when removing the base from the chassis as there are tabs that hold them together!
    • CAUTION: The battery is located on the plastic bottom. The battery is connected to the PCB located near the orange switches and USB
  7. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnect the Battery: adım 7, 2 resimden 1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnect the Battery: adım 7, 2 resimden 2.
    • Use tweezers to disconnect the battery from the PCB.
    • Use caution when removing the PCB! Pull away from the connector. Do not attempt to jiggle the cable as this may loosen/damage the connector
  8. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the PCB: adım 8, 1 resimden 1.
    • Remove the 14 screws with a # 1 Philips screw driver bit
    • To remove the PCB from the aluminum frame, use a spudger to wedge it out.
  9. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disassembly complete: adım 9, 2 resimden 1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disassembly complete: adım 9, 2 resimden 2.
    • The PCB is now removed and able to work on.
    • When you reassemble the keyboard, make sure to put the orange toggles with the two nubs pointing towards the switch side of the aluminum frame.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mike Villasenor
217 İtibar
1 Kılavuz yazıldı
3 Yorum
Feel free to leave advice if you think I should change any steps. This is my first guide. Enjoy!
Mike Villasenor - Yanıt
Hi Mike,
Great job! Check out this article on creating guides–it has some great tips! Looking forward to reading your next one!
Amber Taus -
Do you know what size screws the keyboard uses?
Sam Jackson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 70
Son 30 gün: 300
Her zaman: 5,337
