Ana içeriğe geç
  1. Remove both 8.0 mm Phillips #1 screws, one for each wheel.
    • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  2. Remove the wheels by pulling them away from the RC car.
    • Remove the wheels by pulling them away from the RC car.
  3. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  4. Make note of where each driving gear cover is placed. They only go in one way.
    • Make note of where each driving gear cover is placed. They only go in one way.
    • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
  5. Pry open the two gear covers on both sides.
    • Pry open the two gear covers on both sides.
  6. Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
    • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  7. Slide both axles from the internal axles guides within the car.
    • Slide both axles from the internal axles guides within the car.
    • Reverse the steps to replace the axles.
Sonuç
Rusbell Gonzalez
219 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 5
Her zaman: 151
