Ana içeriğe geç
Giriş
There are a few layers that you have to work through to get to the inside of the Kid Galaxy Explorer. There are screws on the top and bottom holding the Kid Galaxy Explorer together so if it is not coming apart do not pry it open; check for more screws.
Parçalar
Hiçbir parça belirtilmedi.
  1. First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. After the screw has been loosened, lift the cover off.
    • After the screw has been loosened, lift the cover off.
  3. Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
    • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
    • Turn the RC car over to reach the six screws on the bottom.
  5. Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
    • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
    • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
  6. Lift the top Cover off the car.
    • Lift the top Cover off the car.
Sonuç
Eric Studstrup
4 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G2
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
As i can see in the last image. There are some wires still connected with the outer cover. Could have shown couple more images how to get them off. Everything else looks great.
Dishant Patel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 115
