Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
After the screw has been loosened, lift the cover off.
Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
Turn the RC car over to reach the six screws on the bottom.
Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
(Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
Bir Yorum
As i can see in the last image. There are some wires still connected with the outer cover. Could have shown couple more images how to get them off. Everything else looks great.
