Ana içeriğe geç
Kindle 10 Battery Replacement
Neye ihtiyacın var
    1. Kindle 10 Battery Replacement, Battery: adım 1, 2 resimden 1. Kindle 10 Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle 10 Battery Replacement: adım 2, 1 resimden 1.
      • Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle 10 Battery Replacement: adım 3, 2 resimden 1. Kindle 10 Battery Replacement: adım 3, 2 resimden 2.
      • Use the metal spudger to gently lift the screen out of the back frame.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle 10 Battery Replacement: adım 4, 1 resimden 1.
      • Detach the battery connector from the motherboard.
      • The battery pack may be glued on to the gray plastic frame. Take care when prying it out not to rip the battery, since it is made of a lithium polymer which is flammable and deforms easily.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
hzheng2
603 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Konn Fall 2024 UMass Dartmouth, Team 1-2, Konn Fall 2024 üyesi
UMASSD-KONN-F24S1G2
3 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Do you have any replacements if we break the case ?
Calixte Marbach - Yanıt Paylaş
The affiliate-linked battery is incorrect. Don’t make the mistake I made. Do not purchase it.
dj TA630 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 95
Son 30 gün: 479
Her zaman: 4,923
