Ana içeriğe geç
Kindle 10 LED Status Light Replacement
Neye ihtiyacın var
    1. Kindle 10 LED Status Light Replacement, Battery: adım 1, 2 resimden 1. Kindle 10 LED Status Light Replacement, Battery: adım 1, 2 resimden 2.
      • Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle 10 LED Status Light Replacement: adım 2, 1 resimden 1.
      • Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle 10 LED Status Light Replacement: adım 3, 2 resimden 1. Kindle 10 LED Status Light Replacement: adım 3, 2 resimden 2.
      • Use the metal spudger to gently lift the screen out of the back frame.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle 10 LED Status Light Replacement: adım 4, 1 resimden 1.
      • Detach the battery connector from the motherboard.
      • The battery pack may be glued on to the gray plastic frame. Take care when prying it out not to rip the battery, since it is made of a lithium polymer which is flammable and deforms easily.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle 10 LED Status Light Replacement, Motherboard: adım 5, 3 resimden 1. Kindle 10 LED Status Light Replacement, Motherboard: adım 5, 3 resimden 2. Kindle 10 LED Status Light Replacement, Motherboard: adım 5, 3 resimden 3.
      • Remove the two outer silver screws with a T5 Torx screwdriver.
      • Use your fingers to remove the two gold screws in the middle.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle 10 LED Status Light Replacement: adım 6, 3 resimden 1. Kindle 10 LED Status Light Replacement: adım 6, 3 resimden 2. Kindle 10 LED Status Light Replacement: adım 6, 3 resimden 3.
      • Disconnect the two orange clear plastic ribbons on the upper right and center.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle 10 LED Status Light Replacement: adım 7, 2 resimden 1. Kindle 10 LED Status Light Replacement: adım 7, 2 resimden 2.
      • Pry the motherboard away from the display frame
      FixBot'a Sor
      Yorum Ekle
    1. Kindle 10 LED Status Light Replacement, LED Status Light: adım 8, 3 resimden 1. Kindle 10 LED Status Light Replacement, LED Status Light: adım 8, 3 resimden 2. Kindle 10 LED Status Light Replacement, LED Status Light: adım 8, 3 resimden 3.
      • Follow the guide How To Solder to prepare your soldering iron.
      • Turn on the soldering iron.
      • Clean the tip after the old solder has melted by dragging it across a sponge.
      • Prime the soldering iron by touching its tip with a dab of lead-free wire. Your soldering iron is ready when the solder readily melts.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle 10 LED Status Light Replacement: adım 9, 3 resimden 1. Kindle 10 LED Status Light Replacement: adım 9, 3 resimden 2. Kindle 10 LED Status Light Replacement: adım 9, 3 resimden 3.
      • Touch the soldering iron's tip to the two joints on the front and back of the LED for 5 seconds, or longer if it is not melted.
      • Use tweezers to pull out the LED once it is loosened.
      • Always use tweezers to handle components near the soldering tip as it will be hot.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle 10 LED Status Light Replacement: adım 10, 3 resimden 1. Kindle 10 LED Status Light Replacement: adım 10, 3 resimden 2. Kindle 10 LED Status Light Replacement: adım 10, 3 resimden 3.
      • Search for "Through-Hole Soldering" on this How To Solder guide to ensure you replace and solder the LED correctly.
      • Align your new replacement LED in the correct location.
      • Pull the wires on each side of the new LED through the holes in the circuit where the LED was previously.
      • Solder its joints in the back. Be sure the soldering joints create a concave tent shape indicating a strong connection.
      • Use a tool such as tweezers to hold the new LED in place so that your hands are not near the hot soldering iron.
      FixBot'a Sor
      Yorum Ekle
Sonuç
hzheng2
603 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Konn Fall 2024 UMass Dartmouth, Team 1-2, Konn Fall 2024 üyesi
UMASSD-KONN-F24S1G2
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 506
