Giriş
This guide covers the basic steps to replace the page turner keys on the First Generation Amazon Kindle.
Neye ihtiyacın var
Remove the two (2) Phillips #00 screws (3 mm) connecting the ON/OFF Power and Wifi Switches.
Bu adımda kullanılan alet:Tweezers$4.99
Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the spudger.
Lift the flap with the pointed-end of the spudger to detach the ribbon cable indicated in the second image.
Use tweezers to pull the ribbon cable in the third image laterally to detach it.
Remove the two (2) Phillips #00 screws (3 mm) which attach the motherboard to the front casing.
Carefully lift the motherboard off.
The piece marked in the third image may be loose and fall out freely. If it does not fall off, use your fingers or a plastic opening tool to snap it off. Make sure to place it under the motherboard during reassembly, as found in the image.
