Ana içeriğe geç
Kindle 1st Generation SD Card Reader Replacement
Neye ihtiyacın var
  1. Kindle 1st Generation SD Card Reader Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation SD Card Reader Replacement: adım 2, 2 resimden 1. Kindle 1st Generation SD Card Reader Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Kindle 1st Generation SD Card Reader Replacement, SD Card Reader: adım 3, 1 resimden 1.
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Kindle 1st Generation SD Card Reader Replacement: adım 4, 2 resimden 1. Kindle 1st Generation SD Card Reader Replacement: adım 4, 2 resimden 2.
    • Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  5. Kindle 1st Generation SD Card Reader Replacement: adım 5, 2 resimden 1. Kindle 1st Generation SD Card Reader Replacement: adım 5, 2 resimden 2.
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  6. Kindle 1st Generation SD Card Reader Replacement: adım 6, 1 resimden 1.
    • Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
  7. Kindle 1st Generation SD Card Reader Replacement: adım 7, 2 resimden 1. Kindle 1st Generation SD Card Reader Replacement: adım 7, 2 resimden 2.
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the SD Card Reader vertically from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,977
