Ana içeriğe geç
Kindle 3 Battery Replacement
Neye ihtiyacın var
    1. Kindle 3 Battery Replacement, Remove Rear Cover: adım 1, 3 resimden 1. Kindle 3 Battery Replacement, Remove Rear Cover: adım 1, 3 resimden 2. Kindle 3 Battery Replacement, Remove Rear Cover: adım 1, 3 resimden 3.
      • Turn the device upside-down and insert a pry tool between the two case pieces.
      • On the left side just below the buttons there's a delicate ribbon cable that's part of the screen assembly and may be severed by a pry tool. (This is shown in the third photo, it's where the tool is pointing.) Regardless of where you start, stay clear of this area!
      • If you are having trouble getting an initial gap to pry from, run the flat edge of the pry tool along the front-to-back plate seam until it slips into a gap. You can also flex the device slightly and work a tool into one of the lower corners, which have a lot of empty space behind them rather than fragile components.
      • Looking at the back face, another safe place to start is on the right side just below the page turn buttons. (Note the green arrow in the board photo, which is rotated 90 degrees counter-clockwise.) The tool goes between the lower button and the hinge cover slot. If there isn't a slot there, you're on the wrong side!
      • Do not attempt to pry directly on the page turning buttons.
      • Work the pry tool around the edge of the case, releasing the 18 clips. Don't insert your tool too far, or you may damage components near the edges of the device. The clips are all in the outer edge of the backplate anyway. Note that the clip above the power switch is bigger and stronger than the rest.
      • Pull the rear cover off. The remaining two clips near the center of the back are surprisingly strong, but they face in the same direction so don't just pull up. Instead slide the cover slightly towards the top of device to release them.
      • When reinstalling the back cover, slide the bottom edge into place first, and then press up the sides and along the top until all the clips snap into place.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle 3 Battery Replacement, Release Battery: adım 2, 1 resimden 1.
      • Unscrew the two silver 4 mm Phillips screws securing the battery connector.
      • Set the screws aside in a safe place -- there are exposed components and it's easy for them to short-circuit something.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle 3 Battery Replacement, Replace Battery: adım 3, 3 resimden 1. Kindle 3 Battery Replacement, Replace Battery: adım 3, 3 resimden 2. Kindle 3 Battery Replacement, Replace Battery: adım 3, 3 resimden 3.
      • Lift battery out of housing starting at the end that was secured by the screws.
      • Watch out for the odd-shaped silver washers beneath the battery connector (see second photo); they are necessary for proper mating of the electrical contacts when the screws are re-tightened.
      • When reinstalling the battery, make sure the washers are in place. Holding the battery at an angle (see first photo), insert the two retaining tabs on the bottom of the battery into the slots in the case. Then rotate the battery into place and screw down the connector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order, paying attention to the reassembly notes in the individual steps.
112 farklı kişi bu kılavuzu tamamladı.
Allison Monahan
3.163 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-5, Bruce Fall 2014 CSU Fullerton, Team 1-5, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S1G5
4 Üyeler
16 adet Kılavuz yazıldı
25Kılavuz Yorumları
Hi Allison Monahan,
thank you very much for yor help! By using your guide I made my nearly 6 years old Kindle Keyboard fixed - great!
Stefan Schiche - Yanıt Paylaş
I went to mpfproducts.com and ordered my new battery which came in today. I’ve changed out the battery and my Kindle 3 is now charging. YAHOO!!!
Ruth Kuykendall - Yanıt Paylaş
Where did you get the battery? I couldn’t find it on Amazon. Do you have a model number for the battery? Thanks.
sand1k - Yanıt Paylaş
The old Amazon link has been removed. There’s now a link at the top of this guide to an eBay vendor that stocks the battery. Good luck!
Jeff Suovanen - Yanıt Paylaş
Thanks, Allison and IFIXIT!!! God, I love this site. Cheers, Tom
tombeanhall - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 40
Son 7 gün: 175
Son 30 gün: 871
Her zaman: 94,223
