Ana içeriğe geç
Kindle 4 Motherboard Replacement
Neye ihtiyacın var
  1. Kindle 4 Motherboard Replacement, Open front and back covers: adım 1, 3 resimden 1. Kindle 4 Motherboard Replacement, Open front and back covers: adım 1, 3 resimden 2. Kindle 4 Motherboard Replacement, Open front and back covers: adım 1, 3 resimden 3.
    • Follow the Screen Replacement tutorial up to Step 4
    • Open the back cover
    • Remove the front cover
    • Disconnect the battery
  2. Kindle 4 Motherboard Replacement, Disconnect cables: adım 2, 1 resimden 1.
    • Disconnect all flex cables from the board
    • There are 4 connectors to unclip:
    • Right buttons
    • Left buttons
    • Screen
    • Battery
  3. Kindle 4 Motherboard Replacement, Unscrew the board from the back: adım 3, 1 resimden 1.
    • Unscrew the board from the back
    • 3 Torx screws on this side
  4. Kindle 4 Motherboard Replacement, Unscrew plastic casing: adım 4, 1 resimden 1.
    • Unscrew the plastic casing from the front
    • 2 screws
  5. Kindle 4 Motherboard Replacement, Pop the plastic casing off: adım 5, 2 resimden 1. Kindle 4 Motherboard Replacement, Pop the plastic casing off: adım 5, 2 resimden 2.
    • Heat the plastic piece to help unglue it
    • Turn the device and push the piece out through the casing
  6. Kindle 4 Motherboard Replacement, Unscrew board from the front: adım 6, 1 resimden 1.
    • Unscrew board from the front side
    • That’s another set of 2 screws !
  7. Kindle 4 Motherboard Replacement, Remove the board: adım 7, 3 resimden 1. Kindle 4 Motherboard Replacement, Remove the board: adım 7, 3 resimden 2. Kindle 4 Motherboard Replacement, Remove the board: adım 7, 3 resimden 3.
    • The board has no more screws left, but it is still glued to the casing
    • Use some more heat to weaken the glue
    • Lever the board to unglue
    • Then, remove it by sliding it out
  8. Kindle 4 Motherboard Replacement, Taking a peek at the board: adım 8, 2 resimden 1. Kindle 4 Motherboard Replacement, Taking a peek at the board: adım 8, 2 resimden 2.
    • Here is what it looks like with EMC shields removed
    • Don’t try to remove the shields on your new board, they are directly soldered, and you risk damaging the whole PCB.
  9. Kindle 4 Motherboard Replacement, Change the board and test: adım 9, 1 resimden 1.
    • If you have another device from which you extract the new motherboard, run steps 1 to 7 again
    • Place the new motherboard
    • Before closing it back, test the device
    • Replug all connectors, connect the battery last
    • The LED should blink green upon battery reconnexion
    • Try turning the device on
  10. Kindle 4 Motherboard Replacement, Reassemble: adım 10, 1 resimden 1.
    • Unplug the battery again
    • Rescrew the board
    • Replug the battery
    • Reassemble the plastic piece holding the buttons, the front cover, and the back cover
Sonuç
Amazon apparently discontinued service for this model: the service will expect double authentication, which apparently is not implemented in the Kindle firmware.
However, you can still use your Kindle 4 with USB : it is recognized as mass storage, and you can load ebooks in PDF or MOBI format in memory.
Check out the open-source software Caliber to convert your files in a vintage Kindle-friendly format.
2 farklı kişi bu kılavuzu tamamladı.
Eve Redero
3.210 İtibar
10 adet Kılavuz yazıldı
1Rehber Yorum
благодарю за подсказки, спасибо!
vadim - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 107
Her zaman: 3,192
