Ana içeriğe geç
Kindle 7th Generation Back Panel Replacement
Neye ihtiyacın var
  1. Kindle 7th Generation Back Panel Replacement, Front Panel: adım 1, 2 resimden 1. Kindle 7th Generation Back Panel Replacement, Front Panel: adım 1, 2 resimden 2.
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Back Panel Replacement: adım 2, 1 resimden 1.
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Back Panel Replacement, Back Panel: adım 3, 2 resimden 1. Kindle 7th Generation Back Panel Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Back Panel Replacement: adım 4, 1 resimden 1.
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Abby Roulier
1.095 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G28
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 56
Her zaman: 5,835
