Ana içeriğe geç
Kindle 7th Generation Back Panel Replacement
Neye ihtiyacın var
  1. Kindle 7th Generation Back Panel Replacement, Front Panel: adım 1, 2 resimden 1. Kindle 7th Generation Back Panel Replacement, Front Panel: adım 1, 2 resimden 2.
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
    FixBot'a Sor
    Yorum Ekle
  2. Kindle 7th Generation Back Panel Replacement: adım 2, 1 resimden 1.
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
    FixBot'a Sor
    Yorum Ekle
  3. Kindle 7th Generation Back Panel Replacement, Back Panel: adım 3, 2 resimden 1. Kindle 7th Generation Back Panel Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
    FixBot'a Sor
    Yorum Ekle
  4. Kindle 7th Generation Back Panel Replacement: adım 4, 1 resimden 1.
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Abby Roulier
1.167 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G28
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 75
Her zaman: 6,275
