Giriş
Having battery issues that require replacement? Well you're in the right place. You're also in luck: the battery is the easiest internal component of the Kindle 7th generation to replace. Follow this guide and your Kindle should be working in no time.
Neye ihtiyacın var
At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
Run the tool along the seams to pry open the front panel.
23 farklı kişi bu kılavuzu tamamladı.
16 Yorum
Where do I get a new battery from please?
You can get the batteries on Ebay.
