Ana içeriğe geç
Kindle 7th Generation Front Panel Replacement
Neye ihtiyacın var
  1. Kindle 7th Generation Front Panel Replacement, Front Panel: adım 1, 2 resimden 1. Kindle 7th Generation Front Panel Replacement, Front Panel: adım 1, 2 resimden 2.
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Front Panel Replacement: adım 2, 1 resimden 1.
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Abby Roulier
1.095 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G28
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 60
Her zaman: 6,027
