Ana içeriğe geç
Kindle 7th Generation Motherboard Replacement
Neye ihtiyacın var
  1. Kindle 7th Generation Motherboard Replacement, Front Panel: adım 1, 2 resimden 1. Kindle 7th Generation Motherboard Replacement, Front Panel: adım 1, 2 resimden 2.
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Motherboard Replacement: adım 2, 1 resimden 1.
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Motherboard Replacement, Back Panel: adım 3, 2 resimden 1. Kindle 7th Generation Motherboard Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Motherboard Replacement: adım 4, 1 resimden 1.
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
  5. Kindle 7th Generation Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Kindle 7th Generation Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Flip the screen over to face the motherboard and battery pack.
    • Use the blunted precision tweezers to gently unclip and detach the cable connecting the battery pack and motherboard.
  6. Kindle 7th Generation Motherboard Replacement: adım 6, 3 resimden 1. Kindle 7th Generation Motherboard Replacement: adım 6, 3 resimden 2. Kindle 7th Generation Motherboard Replacement: adım 6, 3 resimden 3.
    • Use the tip of the spudger to flip up the small retaining flap on the copper colored zero insertion force (ZIF) connector.
    • Make sure to flip up the flap and not the connection itself.
    • Pull the cable from the connector.
    • No force is required to do this, as the name, ZIF, implies.
  7. Kindle 7th Generation Motherboard Replacement: adım 7, 2 resimden 1. Kindle 7th Generation Motherboard Replacement: adım 7, 2 resimden 2.
    • Similar to the previous step, flip up the retaining flap on the white cable connector.
    • Pull the white cable from the connection.
    • During reassembly, make sure the retaining flaps for both the white and copper colored cable connections are secured. As these are zero insertion force connections, the cables could potentially slide out if this is not done.
  8. Kindle 7th Generation Motherboard Replacement: adım 8, 2 resimden 1. Kindle 7th Generation Motherboard Replacement: adım 8, 2 resimden 2.
    • Disconnect the touch digitiser bridge cable by using your Spudger to lift up the white tabs on both connectors.
    • Use tweezers to pull out the cable.
    • The touch digitiser bridge cable is the one connecting between these two connectors.
  9. Kindle 7th Generation Motherboard Replacement: adım 9, 2 resimden 1. Kindle 7th Generation Motherboard Replacement: adım 9, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the eight 3.0 mm Phillips Head screws.
    • Some screws have washers associated with them. It is important to keep track of the washers and remember which thread they came from.
  10. Kindle 7th Generation Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Michael Griffith
485 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G28
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
This doesn’t look like my 7th generation. Close but not quite the same. Does the motherboard have to be removed to replace the screen?
Shonna Partlow - Yanıt
Anyone know where to buy parts? I’m struggling to find any
Adrianne - Yanıt
yes this is Def not the same as my 7th gen but it's an 8 inch so maybe that's the difference.. all I see is 4 screws holding down the motherboard n I've removed them but still can't get the board loose.. it's like one side of it is held down under these plastic tabs that don't move..
Heather Hodge - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 56
Her zaman: 6,360
