Neye ihtiyacın var
May need to use something to pry it open such as a screwdriver.
After you pop some of the little clips inside, you can use your fingers to remove it completely.
The first photo shows two red circles over the screw that will need to be removed first.
After lifting the tab as shown in the third photo you will need the part number located below bar code.
Next you will need remove all of the little white sliders that hold tabs down. if your fingernails are any shorter than mine you may need to use something for assistance.
Remove all of the wires that trace to the mother board.
Two speaker wires
Wire for battery
Using your fillips screwdriver, remove the screws that have red circles around them.
The screws that have blue circles around them should already be removed at this point but there are two remaining screws under that tab that also need to be removed.
In addition, use your fingers to remove the tab that has a purple square around it.
