Giriş
Remove the back case from your Kindle Fire to access its internal components.
Neye ihtiyacın var
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
14 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Simple to follow instructions .
where to buy the base panel for my kindle fire 7 tablet
