Ana içeriğe geç
Kindle Fire HD 2013 Speakers Replacement
Neye ihtiyacın var
  1. Kindle Fire HD 2013 Speakers Replacement, Speakers: adım 1, 3 resimden 1. Kindle Fire HD 2013 Speakers Replacement, Speakers: adım 1, 3 resimden 2. Kindle Fire HD 2013 Speakers Replacement, Speakers: adım 1, 3 resimden 3.
    • Open up the device by using a plastic opening tool in order to avoid damaging the device.
    • To do so, find the seam along the outer edge of the device and use the plastic tool to pry the back panel up. Doing so may take some force and patience.
  2. Kindle Fire HD 2013 Speakers Replacement: adım 2, 3 resimden 1. Kindle Fire HD 2013 Speakers Replacement: adım 2, 3 resimden 2. Kindle Fire HD 2013 Speakers Replacement: adım 2, 3 resimden 3.
    • There are (4) 3mm T4 Torx screws between both speakers (two each). Remove the ones necessary for whichever speaker needs to be replaced.
  3. Kindle Fire HD 2013 Speakers Replacement: adım 3, 3 resimden 1. Kindle Fire HD 2013 Speakers Replacement: adım 3, 3 resimden 2. Kindle Fire HD 2013 Speakers Replacement: adım 3, 3 resimden 3.
    • After the screws are removed, locate the wire, follow it to where it connects to the main device, and pull up gently until it disconnects.
  4. Kindle Fire HD 2013 Speakers Replacement: adım 4, 2 resimden 1. Kindle Fire HD 2013 Speakers Replacement: adım 4, 2 resimden 2.
    • Remove (2) 3mm T4 Torx screws from the bottom speaker.
  5. Kindle Fire HD 2013 Speakers Replacement: adım 5, 2 resimden 1. Kindle Fire HD 2013 Speakers Replacement: adım 5, 2 resimden 2.
    • Same as Step 3, after the screws are removed, follow the wire to where it connects and pull up gently until it disconnects.
Sonuç
Bir başkası bu kılavuzu tamamladı.
aaa
733 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Sullivan Fall 2016 USF Tampa, Team 2-3, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 402
