Ana içeriğe geç
Kindle Fire HD 6 Battery Replacement
Neye ihtiyacın var
  1. Kindle Fire HD 6 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
    FixBot'a Sor
    Yorum Ekle
  2. Kindle Fire HD 6 Battery Replacement: adım 2, 2 resimden 1. Kindle Fire HD 6 Battery Replacement: adım 2, 2 resimden 2.
    • Carefully separate the back panel from the rest of the device internals.
    FixBot'a Sor
    Yorum Ekle
  3. Kindle Fire HD 6 Battery Replacement, Battery: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    iOpener
    $14.95
    • Gently pry the battery free from the adhesive holding it in place.
    • Take care not to pierce or rupture the battery, which can release dangerous chemicals.
    • If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
    • Be careful not to yank the battery out—you'll need to disconnect a connector before removing the battery completely.
    FixBot'a Sor
    Yorum Ekle
  4. Kindle Fire HD 6 Battery Replacement: adım 4, 2 resimden 1. Kindle Fire HD 6 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Cassandra Beck
885 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G4
4 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you it worked for me.
A bit nervous breaking it down, once I got the back plate off it was very simple, unplugged the battery, reconnected put it back together fired it up , great advice.
Thanks again
Regards
Terry
terry pils - Yanıt Paylaş
The battery removal step did not sufficiently warn about how hard the adhesive used for the battery was, and using the spudger ended up piercing the battery when I tried to pry the battery off.
Sean Collins - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 85
Her zaman: 9,557
