Ana içeriğe geç
Kindle Fire HD 6 Speaker Replacement
Neye ihtiyacın var
  1. Kindle Fire HD 6 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Speaker Replacement: adım 2, 2 resimden 1. Kindle Fire HD 6 Speaker Replacement: adım 2, 2 resimden 2.
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
  4. Kindle Fire HD 6 Speaker Replacement: adım 4, 2 resimden 1. Kindle Fire HD 6 Speaker Replacement: adım 4, 2 resimden 2.
    • Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector. Gently pull it straight up.
  5. Kindle Fire HD 6 Speaker Replacement: adım 5, 2 resimden 1. Kindle Fire HD 6 Speaker Replacement: adım 5, 2 resimden 2.
    • Lift the speaker out of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cassandra Beck
885 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G4
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 22
Her zaman: 730
