Giriş
Make sure your device is powered off before you begin. Then place the device screen down.
*Caution: Some devices may have tape holding the back on.
Neye ihtiyacın var
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Lift up until you hear a slight popping noise.
Repeat along the perimeter of the device to release the clips securing the case halves to each other. Remove the back cover.
Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
Detach the plastic piece that connects the wires to the motherboard using the plastic opening tool.
39 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
Where can you get a replacement battery
Easy peasy! The hardest thing was getting the back cover off (and back on). Our local electronic repair store refused to open the case for me (they’ll never get any business from me), so I asked my dentist to do it, and he did (and loved it). I can’t remember where I ordered the battery from; I just put the model number in a search engine and got several hits. The one I bought was new, cheap ($14), came in two days, and had all the tools with it! Thanks, ifixit; I’ll get a few more years out of this older one, which I use for crosswords puzzles and solitaire; you know, stuff you do in the waiting room. btw, I’m a 78-year-old woman.
Nice work, proud of you.I would have never thought to ask your Dentist.
Dano -
Je voudrais un tuto pour cabler un lecteur de carte DE sur ma kindle Fire hd
