Giriş
Before starting, make sure the device is powered off and placed screen down.
Neye ihtiyacın var
1. Using the plastic opening tool, carefully insert the opening tool on all four corners of the Kindle Fire and lift up until you hear a slight popping noise.
Using the plastic opening tool, start from one corner and go around the Kindle Fire using the tool in a down and up motion to continue to pop off the backing.
After you lift all four corners and you check for tape, it is safe to proceed.
Once all the plastic clips holding the screen to the plastic back of the Kindle Fire are separated, the back should be safe to lift up completely.
9 farklı kişi bu kılavuzu tamamladı.
2 Yorum
A question. I do not know if my Kindle Fire HD is pre or post 2013. Will this work for either one?
