Ana içeriğe geç
Kindle Fire HDX 7" Display Assembly Replacement
Neye ihtiyacın var
    1. Kindle Fire HDX 7" Display Assembly Replacement, Speaker Bezel: adım 1, 3 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement, Speaker Bezel: adım 1, 3 resimden 2. Kindle Fire HDX 7" Display Assembly Replacement, Speaker Bezel: adım 1, 3 resimden 3.
      • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
      • The adhesive is strong and may require an iOpener, or heat gun, to soften.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Fire HDX 7" Display Assembly Replacement: adım 2, 1 resimden 1.
      • Remove the speaker bezel.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle Fire HDX 7" Display Assembly Replacement, Rear Panel: adım 3, 1 resimden 1.
      • Remove the six pink 3mm T3 Torx screws from the back case.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Fire HDX 7" Display Assembly Replacement: adım 4, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 4, 2 resimden 2.
      • Wedge opening picks around the perimeter between the display and back case.
      • Work the opening picks around the perimeter until the two halves disengage from each other.
      • Don't completely separate as the display ribbon cable still connects the two.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Fire HDX 7" Display Assembly Replacement: adım 5, 1 resimden 1.
      • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
      • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle Fire HDX 7" Display Assembly Replacement, Battery: adım 7, 1 resimden 1.
      • Pry up the battery connector with the flat end of a spudger.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Fire HDX 7" Display Assembly Replacement: adım 8, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 8, 2 resimden 2.
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Fire HDX 7" Display Assembly Replacement: adım 9, 1 resimden 1.
      • Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the battery cell.
      • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle Fire HDX 7" Display Assembly Replacement: adım 10, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 10, 2 resimden 2.
      • Slide a few opening picks between the battery and the raised metal edge.
      • Pry upwards to lift the battery up.
      • Step 15 may need to be repeated a few times to weaken the glue.
      FixBot'a Sor
      Yorum Ekle
    5. Kindle Fire HDX 7" Display Assembly Replacement: adım 11, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 11, 2 resimden 2.
      • Apply a small amount of adhesive remover (approximately 1 ml) underneath the battery and wait 2-3 minutes for it to penetrate.
      • You may need to repeat this a few times.
      • Continue prying up the battery.
      FixBot'a Sor
      Yorum Ekle
    6. Kindle Fire HDX 7" Display Assembly Replacement: adım 12, 1 resimden 1.
      • Remove the battery from the mid-frame.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle Fire HDX 7" Display Assembly Replacement, Motherboard: adım 13, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement, Motherboard: adım 13, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Grab the yellow tape with a pair of tweezers and pull upwards to disconnect the press-fit connector.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Fire HDX 7" Display Assembly Replacement: adım 14, 1 resimden 1.
      • Use the flat end of a spudger to disconnect the front camera press-fit connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Fire HDX 7" Display Assembly Replacement: adım 15, 1 resimden 1.
      • Remove the nine 3mm T6 Torx screws from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle Fire HDX 7" Display Assembly Replacement: adım 16, 3 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 16, 3 resimden 2. Kindle Fire HDX 7" Display Assembly Replacement: adım 16, 3 resimden 3.
      • Use a spudger to pry up and disconnect the antenna cable from the motherboard.
      • Pull the antenna cable up and off of the motherboard.
      • Don't remove completely as it's soldered to the frame.
      FixBot'a Sor
      Yorum Ekle
    5. Kindle Fire HDX 7" Display Assembly Replacement: adım 17, 1 resimden 1.
      • Use a spudger to disconnect the second antenna cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Kindle Fire HDX 7" Display Assembly Replacement: adım 18, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 18, 2 resimden 2.
      • Use the flat end of a spudger to pry up and disconnect the front camera press-fit connector from the motherboard.
      • Remove the front camera.
      FixBot'a Sor
      Yorum Ekle
    7. Kindle Fire HDX 7" Display Assembly Replacement: adım 19, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 19, 2 resimden 2.
      • Remove the motherboard from the tablet.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle Fire HDX 7" Display Assembly Replacement, Display Assembly: adım 20, 1 resimden 1.
      • Heating the edges of the tablet will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the edge of the tablet for about 90 seconds in order to soften up the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Fire HDX 7" Display Assembly Replacement: adım 21, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 21, 2 resimden 2.
      • Insert an opening pick between the glass display and the metal mid-frame.
      • Insert a second opening pick above the first.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Fire HDX 7" Display Assembly Replacement: adım 22, 3 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 22, 3 resimden 2. Kindle Fire HDX 7" Display Assembly Replacement: adım 22, 3 resimden 3.
      • Roll the second opening pick all the way around the perimeter of the display.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle Fire HDX 7" Display Assembly Replacement: adım 23, 2 resimden 1. Kindle Fire HDX 7" Display Assembly Replacement: adım 23, 2 resimden 2.
      • Lift up on the glass display to remove it from the metal mid-frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Blake Klein
75.094 İtibar
50 adet Kılavuz yazıldı
10Kılavuz Yorumları
I don’t have access to opening picks or adhesive remover, what can I use in place of these?
Sophie Larson - Yanıt Paylaş
Sophie, I regularly use playing cards, plastic lids from various disposable containers, guitar picks, and little metal objects that I get from parts of a clock or other small mechanical device. You’d be surprised how useful some of the little doodads can be as pick or pry tools. Apart from that: look for little tool kits that come with replacement parts. Many sellers include them as part of the deal. They aren’t nearly as good as the iFixIt tools, but they will do in a pinch until you can afford the better tools.
Christopher Little - Yanıt Paylaş
This guide seems to explain how to remove the display, but not how to replace it with a new one, even though the guide clearly states ‘replacement’. All anyone is left with is a ripped apart HDX? Do you have a guide on how to actually replace the screen and not just take out the old one?
dalebutt - Yanıt Paylaş
I understand where you are coming from. It’s daunting enough to take the thing apart with all the thin ribbon cables and tiny wires, not to mention the PCB and battery removal possibly going wrong. Let me tell you, it’s not too tough to do the replacement by following the instructions in reverse. All you need to do is remember that the fate of the world rests in your steady hand. Just kidding.
My advice: take it one step at a time, take a break if you get impatient or nervous… as long as you need. While you are working on reassembling the device, give it a try in a dry run (without adhesive or screws), then do it for real once (and only when) you are comfortable with the assembly.
Coming to this to do a little screen replacement on the kindle HDX 7” , I noticed your steps seem a bit out of order. Not a major issue as I just scrolled down but some of the steps are in the wrong order, battery, screen and motherboard removal. Which may send some down the wrong path :) Otherwise excellent manual, helped me muchly! Thank you !
Ben - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 7,269
