Ana içeriğe geç
Kindle Fire HDX 7" Micro USB Charging Port Replacement
Neye ihtiyacın var
  1. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: adım 1, 3 resimden 1. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: adım 1, 3 resimden 2. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: adım 1, 3 resimden 3.
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Micro USB Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Rear Panel: adım 3, 1 resimden 1.
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Micro USB Charging Port Replacement: adım 4, 2 resimden 1. Kindle Fire HDX 7" Micro USB Charging Port Replacement: adım 4, 2 resimden 2.
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Micro USB Charging Port Replacement: adım 5, 1 resimden 1.
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Micro USB Charging Port: adım 7, 1 resimden 1.
    • Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
  7. Kindle Fire HDX 7" Micro USB Charging Port Replacement: adım 8, 2 resimden 1. Kindle Fire HDX 7" Micro USB Charging Port Replacement: adım 8, 2 resimden 2.
    • Pry up the ribbon cable from the rear panel with the flat end of a spudger.
    • Remove the micro USB port and power button ribbon cable.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Blake Klein
70.531 İtibar
50 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 6,464
