Giriş
Replacement guide for the motherboard on a Kindle Fire HDX 7” tablet.
The battery can only be disconnected once the motherboard is removed. Be careful not to cause a short with metal tools around the components on the motherboard.
Neye ihtiyacın var
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Grab the yellow tape with a pair of tweezers and pull upwards to disconnect the press-fit connector.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
This is a good tutorial but there is no mention of the bottom two connectors attached to the motherboard and some tips on reattaching these, i.e. the connector cables can be extended and then pulled back to normal to make reattachment possible
Exactly! Followed this tutorial today, wanted to replace motherboard, and almost ripped off the lcd/touch connectors and flat cables because didn’t know they are there. It’s a bit difficult to put them back, be careful.
Neb Sek -
