Ana içeriğe geç
Kindle Paperwhite 1st Generation Case Replacement
Neye ihtiyacın var
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: adım 1, 2 resimden 1. Kindle Paperwhite 1st Generation Case Replacement, Case: adım 1, 2 resimden 2.
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Case Replacement: adım 2, 3 resimden 1. Kindle Paperwhite 1st Generation Case Replacement: adım 2, 3 resimden 2. Kindle Paperwhite 1st Generation Case Replacement: adım 2, 3 resimden 3.
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Case Replacement: adım 3, 1 resimden 1.
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony Nahal
60 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-33, Amido Winter 2013 Cal Poly, Team 3-33, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G33
4 Üyeler
17 adet Kılavuz yazıldı
2 Yorum
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Yanıt
4 years too late but I found this
Pao-Tang Kao - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 74
Her zaman: 9,352
