Ana içeriğe geç
Kindle Paperwhite 2nd Generation Screen Replacement
Neye ihtiyacın var
    1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: adım 1, 1 resimden 1.
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Paperwhite 2nd Generation Screen Replacement: adım 2, 2 resimden 1. Kindle Paperwhite 2nd Generation Screen Replacement: adım 2, 2 resimden 2.
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Paperwhite 2nd Generation Screen Replacement: adım 3, 1 resimden 1.
      • Carefully lift and remove the mid-frame.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle Paperwhite 2nd Generation Screen Replacement: adım 4, 1 resimden 1.
      • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Tyler Davis
2.007 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G2
4 Üyeler
25 adet Kılavuz yazıldı
3Kılavuz Yorumları
My opening tool is orange. Will this still work for me?
FoxRunTime - Yanıt Paylaş
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Yanıt Paylaş
Did this work Liam?
Ben Lowdon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 169
Her zaman: 15,596
