Ana içeriğe geç
Giriş
Amazon’s Kindle Paperwhite 3rd Generation (7th Generation of Kindles) possesses a 3.7 Volt, Lithium Polymer battery (Model No: MC-354775-05). This guide requires that the Kindle is turned off, and that a plastic opening tool, and a PH000 screwdriver are used.
  1. Ensure that the device is turned off before beginning. Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point. Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
    • Ensure that the device is turned off before beginning.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  2. Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame. Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
  3. Gently lift the mid-frame out of the case with your hands.
    • Gently lift the mid-frame out of the case with your hands.
  4. Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery. Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
    • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
  5. Gently lift the battery from the frame.
    • Gently lift the battery from the frame.
Sonuç
54 farklı kişi bu kılavuzu tamamladı.
Micah Smart
2.459 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 14-3, Lacy Spring 2016 USF Tampa, Team 14-3, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G3
4 Üyeler
7 adet Kılavuz yazıldı
15 Yorum
Same for 5th Generation ??
PAUL FRIEND - Yanıt
where can i buy a new battery ?
david horn - Yanıt
you need a taobao.
lol
kassadin -
where can I buy a replacement battery?
boelens - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 97
Son 30 gün: 481
Her zaman: 39,924
