Ana içeriğe geç
Kindle Touch Battery Replacement
Neye ihtiyacın var
  1. Kindle Touch Battery Replacement, Back Cover: adım 1, 3 resimden 1. Kindle Touch Battery Replacement, Back Cover: adım 1, 3 resimden 2. Kindle Touch Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch Battery Replacement: adım 2, 2 resimden 1. Kindle Touch Battery Replacement: adım 2, 2 resimden 2.
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch Battery Replacement, Battery: adım 3, 3 resimden 1. Kindle Touch Battery Replacement, Battery: adım 3, 3 resimden 2. Kindle Touch Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Battery Replacement: adım 4, 3 resimden 1. Kindle Touch Battery Replacement: adım 4, 3 resimden 2. Kindle Touch Battery Replacement: adım 4, 3 resimden 3.
    • Using the flat end of your spudger, gently pry the battery up and remove it.
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Adam Yerly
1.940 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Where can I buy a new battery?
Carla Grobler (Ubbink) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 25
Son 30 gün: 101
Her zaman: 10,459
