Ana içeriğe geç
Kindle Touch Bezel Replacement
Neye ihtiyacın var
  1. Kindle Touch Bezel Replacement, Back Cover: adım 1, 3 resimden 1. Kindle Touch Bezel Replacement, Back Cover: adım 1, 3 resimden 2. Kindle Touch Bezel Replacement, Back Cover: adım 1, 3 resimden 3.
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. Kindle Touch Bezel Replacement: adım 2, 2 resimden 1. Kindle Touch Bezel Replacement: adım 2, 2 resimden 2.
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
    FixBot'a Sor
    Yorum Ekle
  3. Kindle Touch Bezel Replacement, Bezel: adım 3, 2 resimden 1. Kindle Touch Bezel Replacement, Bezel: adım 3, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
    FixBot'a Sor
    Yorum Ekle
  4. Kindle Touch Bezel Replacement: adım 4, 3 resimden 1. Kindle Touch Bezel Replacement: adım 4, 3 resimden 2. Kindle Touch Bezel Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jerome Narine
224 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G5
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
I want to paint The bezel white. Will it come back and fit perfectly after the removal I have to make?
denianyc - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 53
Her zaman: 3,903
